I'm looking for a little insight on the correct procedure to bleed brakes on a VFR800.
The factory service manual is full of crap instruction, VFRD and VFRWorld don't have any concrete tutorials or answers. I have 7 bleed screws, and I'm sure I've got the order down correct.
I have speed bleeders installed which make it super easy, but I'm a little hazy on a couple of steps. Especially the secondary master cylinder on left front caliper.
If you've done this, and wouldn't mind answering this question..
When it says to manually operate the secondary master cylinder on the left front caliper, hardly any fluid comes out of the proportional control valve bleeder; do I use the front lever to maintain pressure to flush that line? and then continue pumping the SMC manually?
