Winter is coming and you will need to keep your battery charged for next year.
This is a Brand New BikeMaster ChargeMaster 365TD Battery Charger & Maintainer. It Chargers, Floats and Maintains your battery. You can keep your battery in your bike and just put this on to float charge over the winter, no need to spend all that time removing then reinstalling your battery.
Specs:
•Triple mode, 7 stage charger
•Assesses battery connection polarity
•Analyzes and diagnoses battery condition
•Recovers mildly and/or heavily discharged batteries
•Bulk charges batteries quickly
•Monitors voltage retention and battery condition
•Maintains battery with low current if the voltage drops below a set limit •Extra long cables for ease of use
•Secure-grip alligator clips
•Weatherproof fuse holder
•Permanent connectors with weatherproof cap
•3 charge rates: MOTORCYCLES (600ma), CARS/BOATS (3600ma), and BOOST (for AGM batteries and cold weather charging)
•Suitable for AGM batteries that require a higher charge voltage
•Especially useful for charging batteries in freezing weather
•Backlit LCD display for use in low light conditions
•Displays real-time charging rate, including voltage and amperage •Designed to be connected for months or even years at a time (winter storage)
•Battery condition monitor indicates if the battery is able to hold a charge or is in need of replacement
•Wall bracket and extra long cables for convenient garage use
•The ChargeMaster 365TD is suitable for all 12V battery types up to 130Ah including: Gel, MF and lead acid
ASKING $80.00
Purchased for $125.00+Taxes and Shipping from:
http://www.topendz.com/mm5/merchant...endz&Product_Code=365TD&Category_Code=Battery
Specs:
ASKING $80.00
