Greetings fellow riders,
I'm relatively new to the riding scene and I've been enjoying my old '83 Magna V45 for two months now and two days ago while riding to work, I noticed that the bike was just suddenly lacking power and started to sputter a little bit. One thing very noticeable was that my tachometer started to have erratic readings and the needle was jumpy.
I did some investigation and below is the summary of it:
1. There's fuel and it is clean since I've been going to the same station and always use the same grade.
2. There's spark on all four cylinders. It's a V4 engine and when I checked the spark plugs, the two upright cylinders close to the fuel tank showed black oily plugs. The other plugs seemed fine. I put a fresh set of plugs and it showed the same after running it around the block.
3. It has two ignition coils and I suspected a bad one but I swapped the coils and still ended up with black/oily plugs in the same set of plugs.
4. It runs fine when idling, but once I ride off, the power isn't there and like I mentioned there's sputtering and hesitation.
5. The engine has 4 carburetors and I just sprayed some carb cleaner and revved it a little but did not help.
6. These engines are known for pre-mature cam wear and I just hope that it's not the cams!
Looking forward to any replies from the technical Gurus in this site!
Just when the weather is getting better then I get this! Arghhh!
Thanks,
Magnalex
Thanks,
Magnalex
