1000RR
COMPLETE FRONT END 04-07 (minus front wheel and fender)
forks, triples, calipers, clipons, master cylinder w lever
forks have new seals and fresh motul fork oil. checked straight.
set of bent forks for spare parts available
$500obo
FRAME
blank, no title
$250
FRAME
Ontario Irrepairable Title
$300
SWINGARM
clean
$75
HARNESS 04/05
$75
ECU 04/05
$75
REAR WHEEL
$100
REARSETS
$50
REAR BRAKES
caliper, lines, master assembly
$50
FRONT WHEEL
has a small lip but its straight, balances and holds air
$100
ROTORS 06/07 320mm
will fit 05+ 600rr and 04/05 1000RR
$100
ENGINE
complete - spun crank bearing. clean covers. top end is good.
$300
CLUTCH CYLINDERS
with lines & lever
$60
FUEL PUMP
$100
BLUE & YELLOW TANK COVER
$60
AIRBOX w/ injectors, etc.
$40
K&N AIR FILTERS w/ K&N oil
$60
COMPLETE LOCKSET with KEY
igintion, tank, seat
$100
600RR
REARSETS 07+
ok shape
$40
CLIPONS 07+
$75
PASSENGER PEGS 07+
$40
EXHAUST MANIFOLD 07+
w. servo
$30
ROTORS
left rotor
$50
WIRE HARNESS 03-06
$75
SEATS
driver is good, small tear in passenger.
$40 both
GREY TANK COVER 07+
some scratches
$20
ARMOUR BODIES RACE GLASS 03-04
needs work, very fixable
$200 as is
$500obo
FRAME
blank, no title
$250
FRAME
$300
SWINGARM
clean
$75
HARNESS 04/05
$75
ECU 04/05
$75
REAR WHEEL
$100
REARSETS
$50
REAR BRAKES
$50
FRONT WHEEL
$100
ROTORS 06/07 320mm
$100
ENGINE
$300
CLUTCH CYLINDERS
with lines & lever
$60
FUEL PUMP
$100
$60
$40
$60
$100
600RR
REARSETS 07+
ok shape
$40
CLIPONS 07+
$75
PASSENGER PEGS 07+
$40
w. servo
$30
ROTORS
left rotor
$50
WIRE HARNESS 03-06
$75
SEATS
$40 both
GREY TANK COVER 07+
some scratches
$20
$200 as is
