Part of my job involves designing components for use in robotics in space. We have onsite fabrication capabilities. I have prototyped parts that were 3D printed and machined in metal.
Interestingly, we have been machining more and more than we were in recent years. If you consider the print time with 3D printing, the pre and post processing like generating supports for the print over a void, then solventing the supports out, dry times, etc. The fabricators are increasingly suggesting and going with machining if the desire is to get the prototype part produced ASAP.
Also, the final part is often to be produced in metal. With the properties of polymers being so different, we end up having to add material to the 3D printed version. And depending on the application this may not be appropriate.
I have a prototype in development now. At the last revision for a milestone, my fabricator people informed me that the round of parts to be produced would be something like 48 of actual print time, not including things like reloading fill, setting up supports, soak time, etc. All in it would have been about a day plus shorter to machine. I found the production rate interesting considering the common thought is 3D printing is faster.
Out of curiosity, what modeling software do you use? And what format of file do you accept?
