Hey,
So I go to the grocery store to pick up some milk, everything is good with no problems at all. I go to start the bike and it sounds like it was misfiring with rough idle/rumbling then dies. Hmm, so I start the bike back up and it idles a bit better but still a bit rough. I managed to limp it home but on the way back it was cutting in and out like running perfectly fine and then super choppy and no power at all and I had to keep it revved higher so it wouldn't stall at the lights. I thought it was going to buck me off!!
Bike is a 2002 R1, all stock performance wise besides a basic slip-on.
Things I did so far:
-drained the gas tank and put new fuel with a tiny bit of injector cleaner and octane booster (thought I might have foul gas)
-took throttle bodies off, no leaks or anything unusual
-did resistance check of the TPS as per manual - good, within spec
-did resistance check on all the coil packs as per manual - good, within spec
-checked the plugs - all good, no discolouration or smell
Put everything back together and still get the same symptoms.
Here is what is happening ->http://youtu.be/mKwJyG2IpW4
As you can hear, idle is rough and chuggs. Slow throttle increase isn't too bad but it still sounds like a bit of misfiring. Fast blips of the throttle just want to make the bike stall and it makes a sound I've never heard before. Almost like the spark or fuel isn't keeping up with eachother and the RPMs just stay put and then it stalls out. No fault codes pop up which makes things even harder to figure out.
The worst part is that everything was perfect and bike was running like a dime as usual, then all of a sudden this happens!! Can anyone help me out??
Thanks in advance.
Thanks in advance.
